Excessive oil consumption is a well-documented issue on 2007–2013 GM trucks with the 5.3L V8 (LC9, LMG, LY5, LMF engines). Some owners report burning 1 quart per 1,000 miles or more without any visible leaks or smoke. Here’s what’s known about the cause and what your options are.
Why the 5.3L Burns Oil
There are two primary causes on these engines:
1. AFM/DoD Lifter Issues (Related)
When AFM cylinders deactivate, oil can be drawn past the valve seals in the deactivated cylinders due to the low-pressure state. Over time, this contributes to consumption, especially if the PCM is deactivating cylinders frequently (highway driving, light throttle).
2. Piston Ring Issue (Primary Cause)
The more significant cause is a piston ring design issue — specifically the low-tension oil control rings used on the 2007–2013 5.3L. Under certain conditions, these rings allow oil to pass into the combustion chamber and burn. GM issued TSB #10-06-01-008 acknowledging this.
Affected engines: Primarily LC9 and LMG (AFM-equipped 5.3L V8), but also some non-AFM variants.
How to Diagnose
- Check your oil level regularly — if it drops significantly between oil changes without leaks or visible smoke, you have consumption
- Acceptable GM spec: 1 quart per 2,000 miles (yes, they really published this — it’s why many owners are frustrated)
- Perform the GM oil consumption test (TSB 10-06-01-008): Use the correct oil fill level marked by dealer, drive 1,000–2,000 miles, measure consumption at each interval
- Check for blue smoke at startup (cold engine) — indicates valve seal wear as well
Fixes and Remedies
Preventive Approach
- Disable AFM with Range Technology RA003B to reduce the deactivation cycle that contributes to oil being drawn past valve seals
- Run higher-viscosity oil — many owners report reduced consumption switching from 5W-30 to 5W-40 or 0W-40 synthetic
- Use full synthetic oil — reduces thermal breakdown that leads to ring sticking
Mechanical Fix
- Full AFM lifter delete using AFM DOD Delete Lifter Kit for 5.3L — replaces all 8 AFM lifters with standard hydraulic lifters, eliminating the cylinder deactivation hardware
- Requires disabling AFM in the PCM via tune after the mechanical delete
- For severe oil consumption, a top-end rebuild with updated piston rings is the definitive fix
If Under Warranty
- Document every oil check and consumption measurement
- Reference TSB 10-06-01-008 and request the consumption test formally
- GM has performed top-end or short block replacements under powertrain warranty for documented cases
Key Takeaways
- Oil consumption on 5.3L GMT900 trucks is a known engineering issue, not just normal wear
- Disabling AFM is the first and cheapest mitigation step
- High-mileage trucks (100K+) with consumption should run full synthetic and monitor levels closely
- If rings are failing, a rebuild is the only real fix — no additive will correct worn rings
