GM 4WD Systems Explained: 2WD / Auto 4WD / 4Hi / 4Lo
GM’s 4WD system has evolved significantly across generations. Understanding what each mode does — and when to use it — prevents drivetrain damage and maximizes your truck’s capability.
The Four Modes Explained
2WD (2H)
Standard operation. Power goes to the rear wheels only. Use for all normal driving on dry pavement.
Auto 4WD (A4WD) — Available on some generations
The transfer case automatically engages the front axle when it detects slip. Useful for light snow or mixed conditions. Generally safe on pavement.
Note: Not all GM trucks have this mode — it was more common on GMT800/GMT900 with the electronic transfer case.
4HI (4H — 4 High)
Locks the front and rear driveshafts together. Use for:
  • Slippery roads (loose gravel, snow, sand)
  • Moderate off-road at speeds up to ~55 MPH
  • Any situation where slip is likely
Do NOT use on dry pavement — the locked axles create axle wind-up and can damage the transfer case and differential.
4LO (4L — 4 Low)
4HI with additional gear reduction (typically 2.48:1 or 2.72:1). Use for:
  • Rock crawling
  • Deep mud or snow
  • Towing in extreme conditions
  • Steep grades at very low speed
Maximum speed in 4LO: Approximately 25–35 MPH (though you should rarely exceed 10–15 MPH for rock crawling)
How to Engage 4WD on Different Eras
Squarebody (1973–1987)
Manual hubs on K10/K20 — must stop, get out, and manually lock the front hubs. Then engage the floor lever to 4HI or 4LO.
4LO engagement: Stop the vehicle, shift to N, engage 4LO on transfer case lever.
GMT400 (1988–1998)
Most K-series have a push-button electronic shift-on-the-fly (ESOF) system:
  • Can shift to 4HI while moving up to ~55 MPH
  • Must stop to engage 4LO: Shift to N, press/hold 4LO button
GMT800/GMT900/K2XX/T1XX
Electronic rotary or button transfer case:
  • 4HI shift-on-the-fly up to 60 MPH
  • 4LO: Slow to under 3 MPH, shift to N, turn dial to 4LO
Common 4WD Issues
Problem Likely Cause
4WD won’t engage Transfer case encoder motor failure
Grinding noise when engaging Didn’t slow down enough before switching
Clicking in turns (4WD) Worn CV axle or front diff binding
4LO works but not 4HI Actuator or TCCM fault
“Service 4WD” light Transfer case encoder motor or module issue
The transfer case encoder motor on GMT800/GMT900 trucks is a known failure item — the Transfer Case Encoder Motor 600-910 is a direct plug-in replacement.
