Full-Size Chevy Maintenance Schedule: What to Do & When
Maintaining a full-size Chevy or GMC truck doesn’t have to be complicated — but ignoring the schedule leads to expensive repairs. Here’s a practical maintenance schedule for gas-powered 1/2-ton and 3/4-ton trucks.
Every Oil Change (~5,000 Miles or Per OLM)
  • Engine oil and filter (see fluid specs thread for correct weights)
  • Visually inspect for leaks under the truck
  • Check all fluid levels: coolant, brake fluid, power steering (if applicable), washer fluid
  • Check tire pressure (cold)
  • Inspect wiper blades
Oil recommendation: Full synthetic Mobil 1 5W-30 for most gas trucks 1999+. The Mobil 1 5W-30 5-quart jug is one of the best-value full synthetic options.
Every 15,000–20,000 Miles
  • Rotate tires (unless directional)
  • Inspect brakes — pad thickness and rotor condition
  • Inspect suspension — ball joints, tie rods, sway bar links
  • Lubricate grease fittings (if present — many modern trucks are sealed)
  • Inspect air filter — replace if dirty
Every 30,000 Miles
  • Replace engine air filter
  • Inspect fuel filter (replace if vehicle uses an inline serviceable filter)
  • Inspect spark plugs (iridium plugs may go 60K+; platinum go 30K–60K; copper go 15K–30K)
  • Transmission fluid drain and fill (4L60E, 6L80, etc.) — use correct spec fluid
  • Transfer case fluid — drain and refill with Autotrak II or equivalent
  • Front/rear differential fluid — drain and refill per spec
  • Inspect CV boots (4WD)
  • Inspect cooling system hoses and clamps
Every 60,000 Miles
  • Spark plugs (if not done at 30K; iridium plugs on modern EcoTec3s)
  • Engine coolant flush and refill (use Dex-Cool or appropriate spec)
  • Inspect timing chain/belt (timing chain on most modern V8s; check for stretch)
  • Replace throttle body if it has never been cleaned (T-Body cleaning every 60K is good practice)
  • Brake fluid flush (especially in humid climates — brake fluid absorbs moisture)
Every 100,000 Miles
  • Full cooling system inspection (water pump, thermostat, hoses)
  • Inspect all engine and trans mounts
  • Transmission rebuild evaluation (have fluid analyzed if concerned)
  • Front suspension rebuild if not done — ball joints, tie rods
When to Deviate from Schedule
Towing or severe duty: Shorten all intervals by 30–50% (especially oil and trans fluid)
Northern climate / rust belt trucks: Inspect suspension and brake components more frequently
High-mileage trucks: More frequent oil changes, especially if any burning is detected
