The in-tank fuel pump is one of the more common repairs on 1999–2006 GMT800 trucks (Silverado, Sierra, Tahoe, Suburban, Yukon). The symptoms are usually gradual — stumbling under hard acceleration, no-start when hot, or a whining/buzzing pump that precedes total failure.
Symptoms of a Failing Fuel Pump
- Hard start or extended cranking, especially when hot
- Stumble or hesitation under heavy throttle (pump can’t maintain pressure)
- Engine dies at highway speed and won’t restart immediately
- Ticking/whining noise from the fuel tank (normal pump sound becomes loud)
- Low fuel pressure reading (spec: 55–62 PSI on 1999–2006 Vortec V8)
What You’ll Need
- Replacement fuel pump module (includes pump, sending unit, strainer, and lock ring)
- Large channel-lock pliers or fuel pump lock ring tool
- Shop rags and a small container for fuel spillage
- Gloves and eye protection
- Multimeter (to test before replacing)
- A-Premium Fuel Pump Module Assembly for Silverado/Sierra 1999–2004 — compatible with 4.3L, 4.8L, 5.3L, 6.0L, and 8.1L applications
Testing the Pump Before Replacement
- Fuel pressure test: Hook a gauge to the Schrader valve on the fuel rail. Key-on pressure should be 55–62 PSI. If it’s below 50 PSI, the pump is suspect.
- Voltage test: Access the fuel pump connector at the top of the tank. At key-on, you should see battery voltage. If voltage is present but pump doesn’t run = bad pump. If no voltage = bad relay or fuse.
- Relay test: The fuel pump relay is in the underhood fuse block. Swap it with a like relay to rule out relay failure.
Step-by-Step Fuel Pump Replacement
Safety First: Work in a well-ventilated area away from ignition sources. Have a fire extinguisher handy.
Depressurize the fuel system: Remove the fuel pump fuse and crank the engine until it dies (or stalls). This bleeds residual pressure.
Disconnect the battery negative terminal
Drop the spare tire (if applicable) and support the tank with a floor jack
Disconnect the fuel filler neck hose at the tank inlet
Unplug the fuel pump wiring harness and fuel lines at the top of the tank (use quick-connect disconnect tools)
Remove the tank straps (typically two bolts per strap) and lower the tank carefully
Clean the top of the tank around the pump module before opening — prevent debris from entering
Rotate the lock ring counterclockwise using the lock ring tool or large channel-locks
Lift the pump module straight out — do not bend the float arm
Transfer the strainer to the new module if not included
Install new module, align the tabs, and torque the lock ring clockwise (firm/snug — do not overtighten)
Reinstall tank, reconnect all lines and wiring, reconnect battery
Prime the system: Turn key to ON (don’t start) 3–4 times for 3 seconds each to prime the pump before first start
Tips & Notes
- Replace the fuel filter at the same time (99-02 have inline filter near the frame rail, 03-06 do not)
- If your truck has dual tanks (some Suburbans/Extended cabs), check which tank failed
- OEM Delphi pumps are the preferred brand for durability; aftermarket options work well if quality-sourced
- You may find it easier to lift and remove the bed,(if lifting tools are readily available), or to lift and slide the bed back to expose the tank.
