Fuel gauge lying to you? Sender or cluster — what did yours turn out to be?
Every GMT800 owner eventually meets the lying fuel gauge — empty with half a tank, needle dancing on the highway, low-fuel chime right after a fill-up. And it’s always one of two things: the sender card in the tank (sulfur contamination wearing the contacts) or the cluster itself (especially on 03–06 trucks with the known gauge motor problem).
The five-minute tiebreaker: read the fuel level percentage with a scan tool and compare it to what’s actually in the tank. Scan data wrong = sender. Scan data right, gauge wrong = cluster.
Full decision guide: Silverado Fuel Gauge Wrong or Erratic: Sending Unit vs Cluster
Let’s hear the outcomes:
  • Which was yours — sender or cluster? And did you test first or guess?
  • Anyone drop the tank on a guess and find out it was the cluster? (You’re among friends.)
  • If you did the sender: did you do the pump at the same time, and any regrets either way?
  • Did the fuel-system-cleaner trick do anything for yours, or was that a waste of a bottle?
