Front End Rebuild: GMT400 Ball Joints, Tie Rods & CV Axles
The 1988–1998 GMT400 trucks use a double-A-arm front suspension with coil springs (on 2WD) or a torsion bar setup (on 4WD), upper and lower ball joints, an inner and outer tie rod on each side, and a center link/idler arm setup. When any of these wear out, you’ll feel it in the steering and handling immediately.
Signs You Need Front End Work
  • Clunking or popping over bumps — ball joints, sway bar end links
  • Wandering or vague steering — worn tie rods or center link
  • Steering pulls to one side — worn tie rod, alignment out
  • Shimmy or death wobble — bad ball joints + worn tie rods = dangerous combo
  • Play in the steering wheel — idler arm or drag link worn
Full Front End Rebuild Parts List (K1500/K2500 4WD)
A complete front end rebuild typically includes:
  • Upper ball joints (x2)
  • Lower ball joints (x2)
  • Inner tie rod ends (x2)
  • Outer tie rod ends (x2)
  • Sway bar end links (x2)
  • Idler arm
  • Pitman arm
A complete kit like the 14pc Front Suspension Kit for K1500/K2500 1995–1999 covers all the major wear items in one box — significantly more economical than buying individual parts.
Ball Joint Inspection
Upper ball joint: Grease-able type on most GMT400 trucks. Inspect by lifting the front axle under the lower control arm and checking for play in the upper joint. More than 0.050" of axial play = replace.
Lower ball joint: Load-bearing on the GMT400 4WD. Check vertical play — any noticeable slop is too much.
Tie Rod Inspection
  1. Park on level ground, chock rear wheels
  2. Grab the tire at 9 and 3 o’clock
  3. Wiggle left and right — any clunking at the tie rod ends = worn
  4. Then grab at 12 and 6 o’clock — any play here points to ball joints or wheel bearings
Idler Arm & Center Link
The idler arm is on the passenger side and mirrors the Pitman arm on the driver side. When the idler arm wears, the entire steering geometry shifts. This is a very common failure point on high-mileage OBS trucks.
Test: With tires on the ground, have a helper move the steering wheel while you watch the idler arm. Any vertical movement in the idler arm = replace it.
Post-Rebuild Alignment
After any front end work, always get a wheel alignment. On GMT400 trucks:
  • Camber: Adjusted via eccentric cam bolt on the upper control arm
  • Caster: Adjusted via shim on the upper control arm crossmember mounting bolts
  • Toe: Adjusted at the inner tie rod
Spec: Caster 2.5–4.5°, Camber 0 to -0.5°, Toe-in 0.06"–0.14"
Don’t skip alignment after a front end rebuild — even new parts will wear prematurely if alignment is off.
