The 2014–2018 K2XX EcoTec3 V8 responds extremely well to tuning. The factory PCM calibration leaves significant power on the table — particularly on the 5.3L and especially the 6.2L. Here’s what your options are and what to expect.
Why Tune a K2XX?
Even a stock EcoTec3 benefits from a tune:
- Disable AFM/DoD (most important reason for long-term reliability)
- Fix 8L90 shift hunting — the factory 8-speed tune is notoriously glitchy; a custom tune resolves most of it
- Remove speed limiter and rev limiter for track or highway use
- Optimize fuel and spark tables for the actual octane you run
- Unlock 91+ octane gains — the 5.3L is knock-limited from the factory; 91 octane + tune = real gains
Option 1: HPTuners — Full Custom Tune
HPT MPVI4 Interface is the gold standard for GM PCM tuning. Works with a local or remote tuner to do a full custom calibration on your specific truck.
Pros: Full control, best results, can tune every table
Cons: Need a tuner (cost $150–$350 for a remote custom tune), requires VCM credits per ECU
Best for: Anyone making real power mods (cam, headers, intake) or wanting the best possible drivability fix
Option 2: EFI Live
Similar capability to HPTuners. Often preferred by diesel tuners; also widely used for gas trucks.
Option 3: Handheld Tuner (Hypertech, DiabloSport)
Pre-loaded tunes on a plug-in device. Faster and cheaper than a full custom tune, but less flexible.
Pros: Plug in and go; good for stock or mildly modded trucks
Cons: Not a true custom tune; may not address all 8L90 issues
Realistic Power Gains (5.3L L83, 91 Octane Tune)
| Condition | Rear Wheel HP |
| Stock (87 octane) | ~305 rwhp |
| Tune only (91 oct) | ~330–345 rwhp |
| Tune + cold air intake | ~350–360 rwhp |
| Tune + intake + headers | ~380–400 rwhp |
The 6.2L responds even better — gains of 40–60 rwhp on 93 octane are commonly achieved.
What to Fix First With a Tune
- AFM disable — most important for longevity
- 8L90 shift calibration — firm up shifts, eliminate hunting
- Fuel and spark — run 91 octane maps
- Rev limiter — raise from 5,800 to 6,200+ if doing performance work
A well-tuned K2XX 5.3L is a completely different truck to drive.
