Duramax Overheating and High EGT: LLY Coolant Temp Fix and Cooling System Upgrades
The LLY Duramax (2004-2005) is specifically known for overheating under load — it was the first Duramax to get the larger injectors and more power, but the cooling system wasn’t upgraded to match. High EGTs on any Duramax under extended towing are also a major concern.
LLY OVERHEATING PROBLEM
  • Factory thermostat opens too late — engine runs hot before cooling kicks in
  • Factory radiator was undersized for the LLY’s increased heat output
  • Common symptom: temp gauge climbing to 220–230°F under sustained load
  • Fix: lower-temp thermostat, performance radiator, and correct coolant
EGT (EXHAUST GAS TEMPERATURE) — WHY IT MATTERS
  • EGT measures how hot the exhaust is leaving the cylinder
  • High EGTs melt pistons, damage turbos, and burn injector tips
  • Safe limit: sustained 1200°F, peak 1400°F
  • Common causes of high EGT: restricted intake, restricted exhaust, low boost, fuel delivery issues
HOW TO LOWER EGTs
  • Cold air intake — more air = cooler combustion
  • Intercooler upgrade — cools the air charge before it enters the cylinder
  • Up-pipe fix — factory up-pipes crack and leak hot exhaust before the turbo on LB7/LLY
  • Lift pump — ensures adequate fuel delivery at WOT
  • Tune — a good tow tune adds fuel timing to reduce EGT under load
EGT MONITORING
  • Install a pyrometer (EGT gauge) — the single most important gauge for diesel towing
  • Mount probe in the exhaust manifold before the turbo for most accurate reading
Recommended Parts
