Dakota Digital makes some of the best gauge upgrades available for classic Chevy trucks. Are they worth the investment?
What Dakota Digital Offers
Dakota Digital makes complete gauge systems that are designed to look factory-correct but use modern stepper motors and electronic sensors for accurate readings. Their VHX series for classic trucks provides:
- Digital/analog hybrid display
- Accurate speedometer (programmable for tire and gear changes)
- Oil pressure, fuel level, coolant temp, and voltage
- Optional tachometer
- Customizable backlighting color
The Case For Dakota Digital:
- Factory instruments on 50+ year old trucks are notoriously inaccurate
- Original gauges require a working cluster harness and often fail
- Speedometers are cable-driven and often off by 5–10+ mph
- Modern gauges are essential if you’ve swapped engines or changed rear gear ratios
The Case Against:
The cost — typically $500–800 for a full system — is significant. If budget is tight, a rebuild of original gauges or a generic aftermarket cluster is cheaper.
Bottom Line:
If you’re doing a quality restomod build, Dakota Digital gauges are absolutely worth it. They look right, work right, and add a ton of driver confidence.
While you’re at it, upgrade your ignition to a Voltstorm HEI Distributor — the improved spark quality helps your new gauges read accurate idle and performance data.
