CP4 Pump Failure on LML Duramax: Why It Fails, What It Destroys, and How to Protect Your Engine
The CP4.2 injection pump on the 2011–2016 LML Duramax is the most catastrophic single-point failure in the Duramax lineup. When it fails, it does not just stop working — it destroys itself and sends metal debris through the entire high-pressure fuel system.
WHY IT FAILS
  • The CP4 is a German-designed Bosch pump engineered for European ultra-low sulfur diesel
  • US diesel has slightly less lubricity than European spec — the CP4 relies on fuel for internal lubrication
  • The pump’s internal roller fails without adequate lubrication
  • Failure sends metal fragments through injectors, fuel rails, and return lines
SYMPTOMS
  • Single hard crank event and then nothing — no restart
  • White/grey smoke before catastrophic failure
  • Loss of power with no warning
  • Fuel pressure code P0087
CONSEQUENCES
  • The entire fuel system must be cleaned or replaced — injectors, fuel lines, rails, low-pressure pump
  • Average repair cost: $8,000–$15,000 at a dealer
  • Entire high-pressure fuel system is contaminated
PREVENTION
  • Add a lift pump BEFORE the CP4 — increases inlet fuel pressure and lubricity
  • FASS and AirDog are the most proven options
  • Add a diesel fuel additive like Stanadyne to every tank — improves lubricity
Recommended Parts
Update: the full FSC guide on this is now live — covers the failure mechanics, the early-warning filter checks, the disaster-prevention bypass kit, and the emissions-compliant CP3 conversion route:
LML CP4 Pump Failure: Why It Happens and How Owners Protect Against It
If you’re running protection (or found glitter in a filter), post your setup and mileage — the community survival data is the most useful part of this thread.
