CP3 Conversion on LML Duramax: Why to Do It, What It Costs, and How Much Power It Unlocks
The CP3 conversion on LML Duramax is one of the most impactful reliability and power mods available for the 2011-2016 trucks. It replaces the failure-prone CP4.2 injection pump with the proven CP3 design used on earlier Duramax engines.
WHY THE CP3 CONVERSION?
  • The factory LML CP4 pump has a catastrophic failure mode that destroys the entire fuel system
  • The CP3 (used on LB7 through LMM engines) is more durable and tolerant of US diesel’s lower lubricity
  • A CP3 conversion eliminates the CP4 failure risk entirely
  • With larger injectors and a tuned LML, the CP3 can support 700+ rwhp
WHAT’S INVOLVED
  • Remove the factory CP4.2 pump
  • Install a CP3 pump adapted to fit the LML’s fuel system
  • Fleece Performance makes the most popular direct-fit conversion kit
  • Requires a tune to adjust fuel trim tables for the CP3’s different delivery characteristics
  • Add a FASS or AirDog lift pump — critical to ensure adequate CP3 inlet pressure
POWER POTENTIAL WITH CP3 CONVERSION
  • Stock LML with CP3 + tune: 450–500 rwhp
  • With upgraded injectors: 600–700 rwhp
  • With compounds and built Allison: 900+ rwhp possible
FUEL SYSTEM PRECAUTIONS
  • Always pair with a lift pump at 95 GPH minimum
  • Use Stanadyne or similar lubricity additive at every fill
  • Replace fuel filters more frequently after conversion
Recommended Parts
