The stock front suspension on a 1947–1972 Chevy truck is a solid beam axle or early IFS design — functional but not designed for modern performance. Here are your main upgrade paths.
Keep Stock – Best for Purists
If your goal is a period-correct build, freshened stock suspension with new kingpins, tie rod ends, and shocks will handle well. Add a 1" front sway bar and quality Monroe or Gabriel shocks for a significant improvement in ride and handling.
Mustang II IFS – Most Popular Swap
The Mustang II front crossmember is the most popular IFS swap for classic trucks. It provides coilover suspension, rack and pinion steering, and a much lower spindle height for aggressive stance.
Benefits:
- Dramatically improved handling and steering feel
- Supports aggressive lowering without harsh geometry changes
- Many bolt-in crossmember kits available
- Compatible with nearly any wheel/tire combo
You’ll also want to upgrade your wiring when you do suspension work — the Painless Performance 10101 Classic Chassis Harness is the benchmark for classic truck rewires.
Helix/Art Morrison IFS
Premium options from Helix Suspension and Art Morrison offer full custom front clip replacements with modern geometry. These are $3,000+ but provide superior engineering.
What’s Your Build Goal?
Post your build details below — let’s help you figure out the right suspension path.
