The bed wood on most surviving classic C10 trucks is either rotted, warped, or completely missing. Replacing it is one of the most satisfying restoration tasks you can do — and it dramatically improves the look and value of the truck.
This thread covers wood species options (oak, pine, treated pine, composite), standard vs hidden hardware, staining and sealing techniques, and how to match original stripe patterns. We also compare DIY cuts vs pre-cut bed kit kits.
For any metalwork and rust treatment around the bed stakes before installing new wood, the Rust-Oleum Rust Reformer helps treat bare metal bed crossmembers before covering them with the new boards.
What wood did you use in your classic C10 bed and how did you finish it?
