Classic Chevy ID Guide: Advance Design vs Action Line (1947–1972)
Trying to figure out what generation your classic Chevy truck is? This guide breaks down the difference between the two main classic eras so you can identify your truck and find the right parts.
Advance Design (1947–1955)
Chevy’s first post-war truck series. These trucks are known for their rounded, streamlined styling with split windshields (on later models) and a cab-forward design that was bold for its time.
Key ID Points:
  • 1947–1953: Round body, split windshield (split glass), no door vent windows initially
  • 1954–1955: Updated grille and trim details
  • Inline-6 “Thriftmaster” or “Loadmaster” engines standard
  • No VIN in the modern sense — engine stampings and cowl tag are your ID sources
Popular Upgrades: LS swap mounts, modern wiring harnesses, disc brake conversion kits
Task Force / Action Line (1955–1959) and Second Series (1960–1966)
The first generation with a more square, car-like cab. The 1955 brought the small-block V8 option for the first time.
Key ID Points:
  • 1955 “Task Force” introduced the new cab style
  • 1960 brought independent front suspension (IFS) replacing solid front axles
  • 1963–1966 trucks got a revised grille and trim updates
  • Engine options: 235 inline-6, 265/283/327 small-block V8
C/K Action Line (1967–1972)
The most popular classic Chevy era for builders and collectors. Square body style, coil front suspension, and wide availability of parts.
Key ID Points:
  • 1967: All-new body design — flat hood, squared-off cab
  • 1968: Side marker lights added (federal requirement)
  • 1969: Updated grille
  • 1972: Last year before the Squarebody (1973) redesign
  • VIN decoding: 10-digit on cowl tag — position 4 is engine code, position 6-10 is serial
C vs K:
  • C = 2WD (standard)
  • K = 4WD
Cab/Bed Styles:
  • Stepside (flareside) — separate rear fenders, narrow bed
  • Fleetside — flush bed sides, wider box
Useful Reference Charts
Year Range Era Name Front Susp V8 Available
1947–1955 Advance Design Solid Axle No (1955: Yes)
1955–1959 Task Force Solid Axle Yes
1960–1966 C-Series / K-Series IFS Yes
1967–1972 Action Line IFS Yes
Use this guide to confirm your year range before ordering parts. Part numbers and fitment vary significantly between these eras.
