Best Weight Distribution Hitch for Full Size Truck – Ranked
A weight distribution hitch is essential safety equipment for any full-size truck that regularly tows over 5,000 lbs. Here’s how to choose the right one.
Why Weight Distribution Matters
When you hitch a heavy trailer, the tongue weight pushes down on the rear of the truck and lifts the front. This reduces front tire contact, decreases steering response, and can make the truck feel unstable at speed.
A weight distribution hitch transfers some tongue weight back to the front axle, leveling the truck/trailer combination.
When Do You Need It?
  • Trailer weighs over 5,000 lbs
  • Tongue weight exceeds 600 lbs
  • The front of the truck rises noticeably when hitched
Best Weight Distribution Hitches:
1. Camco Eaz-Lift ReCurve R3 (Best Value)
The Camco Eaz-Lift ReCurve R3 is a highly-rated system with:
  • 1,000-1,200 lb tongue weight capacity
  • Integrated sway control
  • Adjustable spring bars
  • Tilt-up bar retention system for easy hook-up
2. Equal-i-zer 4-Point Hitch
The 4-Point Equal-i-zer integrates weight distribution and sway control in a single compact system. No chain hookup required.
3. Reese ProRound
Reese’s ProRound is a premium round bar system with excellent build quality and widespread dealer support.
Setting It Up:
After installation, a proper setup requires:
  • Measuring front and rear truck height before hitching
  • Adjusting spring bar tension to restore level
  • Checking tongue weight with a scale
What trailer are you running?
