Best Turbo Upgrades for LBZ and LMM Duramax: Single vs Compound and What to Expect
The LBZ and LMM Duramax share the same basic turbo setup — a variable geometry turbocharger (VGT) that controls boost through movable vanes. The factory turbo is good, but it’s a limiting factor once you start pushing serious power through tunes and fueling mods.
FACTORY TURBO LIMITATIONS
  • Factory VGT can support 400–450 rwhp in good condition
  • Above 400 rwhp the compressor wheel starts to surge under load
  • VGT vanes wear and stick on high-mileage trucks — causes black smoke and power loss
SINGLE TURBO UPGRADES
  • Stage 1: Cleaned/rebuilt VGT — good starting point if factory unit is worn
  • Stage 2: Larger wheel drop-in — S300 or similar wheel in factory housing
  • Stage 3: Full replacement turbo — Fleece Cheetah, Garrett GT4088R, BorgWarner S400
  • Gains: 30–50 rwhp over stock with a supporting tune
COMPOUND TURBO SYSTEMS
  • Two turbos in series — smaller charger feeds the factory turbo
  • Dramatic improvement in spool time and EGT control under load
  • Gains: 150–250+ rwhp depending on setup and fuel
  • Fleece Performance compound kits are the most popular option
WHAT YOU NEED TO SUPPORT A TURBO UPGRADE
  • Professional tune from EFI Live or Autocal
  • Upgraded intercooler — factory unit becomes restrictive above 400 rwhp
  • Lift pump — especially on LML trucks
  • EGT gauge — keep exhaust temps below 1200°F
Recommended Parts
