Best Seat Upgrade for Classic C10 – Bench vs Bucket
The seat in your classic C10 is your connection to the driving experience. Whether you keep a bench or go buckets depends on your build vision.
Original Bench Seat – Keep It Classic
A freshly recovered factory bench seat is the quintessential classic truck look. It holds 3 people, has a flat floor, and maintains period-correct style. If you’re going to shows or want a true vintage aesthetic, restore the bench.
Front Buckets – Better Driver Experience
Bucket seats from a late-model car (especially from Camaro, Mustang, or truck-specific aftermarket seats) give you proper bolstering and support for driving. Many builders use late-model GM or Ford seats with custom mounting brackets.
Aftermarket options from Corbeau, TMI Products, and Classic Industries are direct-fit for most classic truck year ranges.
Column Shifter vs Floor Shifter
If you swap to buckets, you’ll likely want a floor shifter. The Hurst shifter is the classic choice for TH350/TH400 automatics, while a B&M Ratchet can give a more modern feel.
Seat Covers
If you’re restoring the original bench or a used bucket, quality seat covers can transform the interior for a fraction of reupholstery cost. Look for covers specific to your year range from Classic Industries or LMC Truck.
The Painless 10101 Classic Wiring Harness is also worth doing at the same time if you’re doing a full interior refresh — routing new wires behind the dash is much easier with seats out.
