Running board LED lighting is a popular accent upgrade that improves entry visibility and the truck’s visual presence. Here are the best options.
Why Running Board Lights?
Running board accent lights:
- Improve visibility when entering/exiting at night
- Add a premium appearance to the truck
- Can be integrated with door-open trigger for automatic activation
- Work well on lifted trucks with more distance to the ground
Best Running Board Light Options:
1. Nilight Rock Light Pods (Most Popular)
The Nilight RGB Rock Lights 10-Pod works excellently as running board accents. Mount 2-4 pods per running board for even illumination. App-controlled colors and patterns.
2. LED Light Strip Under Running Boards
Generic flexible LED strips (white or RGB) can be adhered to the underside of running boards. Simple installation, clean look.
3. Rigid Industries E-Series Spot (Premium)
For functional rather than decorative lighting, Rigid’s compact pods provide extremely bright white illumination.
Activation Options:
- Manual switch: Simple on/off from inside the cab
- Door-open trigger: Lights come on when you open any door. Wire to the door panel circuit.
- App-controlled (RGB): Control via phone app for shows and events
Installation:
Running boards have mounting points underneath. Self-tapping screws or adhesive magnetic mounts work for most applications. Route wiring through the rocker panel area to the cab or fuse box.
Combine with LED headlight upgrades for a complete exterior lighting overhaul.
