Best License Plate Backup Camera for Silverado – Easiest Install
A license plate-mounted backup camera is the easiest way to add rear view visibility to any Silverado. Here’s the complete guide.
Why License Plate Mount?
License plate cameras offer the cleanest, simplest installation:
  • No drilling or body work required
  • Mounts to existing license plate bolts
  • Camera angle is ideal for a full-size truck
  • Compatible with most aftermarket head units
Best License Plate Camera Options:
Budget Option:
The GLK License Plate Backup Camera is a highly rated budget option. Features:
  • HD front/rear view with 7 LED night vision
  • 170° viewing angle
  • Waterproof construction
  • Universal 12V power connection
At under $20, it’s hard to beat for a basic backup camera installation.
Mid-Range:
The Peak PKC0BU Backup Camera is a slightly more premium version with color correction and better night performance.
Installation Process:
  1. Remove the license plate from the truck
  2. Attach the camera bracket behind the plate
  3. Reinstall the plate — camera peeks over the top
  4. Route the power/video wire through the bumper cavity
  5. Run the wire along the frame to the cab under the truck
  6. Connect to the backup input on your head unit
  7. Connect the trigger wire to the reverse light circuit
Total time: 2-4 hours depending on truck model and wire routing complexity.
Pair With:
The Kissound 7" Double DIN head unit has a backup camera input with auto-switching when reverse gear is selected.
