Best LED Light Bar for Full Size Truck – Roof vs Bumper Mount
LED light bars are the most impactful off-road lighting upgrade for a full-size truck. Here’s how to choose between roof and bumper mounting.
Roof Mount vs. Bumper Mount:
Roof Mount:
  • Higher elevation = longer throw and wider coverage
  • Better for high-speed desert running
  • Provides light beyond what headlights cover
  • More visible to oncoming traffic
  • Legal: typically allowed as auxiliary off-road lighting when not used on public roads
Bumper Mount:
  • Better for low-speed technical terrain (rocks, trails)
  • Illuminates directly ahead at ground level
  • Less wind noise and drag than roof mount
  • Easier installation on most trucks
Best LED Light Bars:
1. Nilight 25" 162W LED Light Bar (Best Value)
The Nilight 25" 162W Light Bar includes a complete wiring harness, mounting brackets, and delivers strong output. The combo spot/flood beam pattern provides both distance throw and wide coverage.
Excellent choice for roof or bumper bracket installation.
2. Rigid Industries SR-Series
Rigid’s premium light bars use superior lens design and binned LEDs for the best beam pattern available. Premium pricing reflects professional-grade quality.
3. Baja Designs Squadron Pro
Baja Designs makes racing-proven lights with exceptional durability. Used in desert racing at speeds over 100 mph.
Legal Note:
LED light bars cannot be used on public roads in most US states when aimed forward. They are for off-road use only. Install with a clearly labeled off-road-only switch inside the cab.
