Best Headlight Upgrades for GMT900 (Halogen vs LED vs HID)
Best Headlight Upgrades for GMT900 — Halogen vs LED vs HID
The factory halogen headlights on the 2007–2013 Silverado, Sierra, Tahoe, and Yukon are adequate at best. Yellow output, mediocre beam pattern, and a dim low beam are common complaints. Here’s an honest comparison of your options.
The Problem with Factory Lights
  • Output is dim compared to modern standards
  • Color temperature is yellow/warm (~3,200K), which is harder on the eyes and less visible in bad weather
  • Beam pattern from the factory reflector housings can scatter — lots of light sideways, not enough down the road
  • Headlight lenses yellow and haze over time, further reducing output
Option 1: LED Bulb Drop-In
The easiest upgrade — swap the halogen H13 or 9012 bulb for an LED replacement.
Pros:
  • Simple plug-and-play installation
  • Brighter output than halogen
  • Long lifespan
  • Available in 5,000K–6,000K white light
Cons:
  • Not all LED bulbs work well in reflector housings — cheap LEDs scatter light wildly and can blind oncoming traffic
  • Some units cause flickering or error codes without a canbus adapter
  • Output is inconsistent between brands — cheap LEDs are often just marketing numbers
Best brands: Auxbeam, Cougar Motor, GTR Lighting (budget to mid-range), Diode Dynamics, Morimoto (premium)
Option 2: HID Kit (High-Intensity Discharge)
HID bulbs produce significantly more light than halogen, with a clean white or blue-white output.
Pros:
  • Substantially brighter than factory halogen and most LED drop-ins
  • 4,300K–5,000K color temperature looks excellent
  • Great visibility in rain and fog compared to higher-kelvin LEDs
Cons:
  • Requires a ballast and wiring — more complex installation
  • Warm-up time (1–2 seconds to full brightness)
  • Factory reflector housings are not designed for HID — hot spots and beam scatter are common without a projector lens
  • Illegal in some jurisdictions without proper projector housing
Note: HID in a reflector housing without a projector shutter is essentially an oncoming-traffic hazard. If you go HID, do it right — pair it with a projector retrofit.
Option 3: Projector Housing Retrofit (Best Overall)
The correct solution for maximum output and proper beam pattern. This involves retrofitting a projector lens and shroud into the factory headlight housing, usually with either HID or LED output.
Pros:
  • Proper beam cutoff — no glare for oncoming traffic
  • Excellent output down the road where you actually need it
  • Works with either HID or quality LED projector units
Cons:
  • Most expensive option ($300–$800+ depending on quality)
  • Installation is more involved (retrofitting requires careful work)
Alternatively: Full replacement projector housings from brands like Spyder or Anzo give you a projector look in a bolt-in package. These are better than stock reflectors but not as good as a custom retrofit.
Also: Don’t Overlook the Lenses
Factory headlight lenses on GMT900 trucks frequently yellow and haze, and a hazed lens scatters light that should be going down the road. Restoring the lens is the cheapest thing you can do to a headlight, and it is worth doing before you spend money on bulbs.
How much you get back depends entirely on how far gone the lens was to start with. We have not put a meter on it, so we are not going to quote you a percentage — be skeptical of anyone who does. Do the lenses first, then judge whether you still need a bulb or housing upgrade.
  • Meguiar’s headlight restoration kit, or separate wet/dry paper plus a protective coating
  • Sylvania or 3M lens restoration systems also work well
  • Budget real time for it. A heavily oxidized lens is not a 30-minute job
Full walkthrough with the grit sequence, masking and coating steps: DIY Headlight Restoration on My 2007 Avalanche — 400 to 3000 Grit + Coating
Bottom Line
For a quick and affordable improvement: quality LED drop-in bulbs (spend at least $60–$80/pair, not $15 Amazon specials) with lens restoration will noticeably improve visibility.
For serious improvement: look at a quality replacement projector housing paired with HID or high-end LED. The difference is night and day.
Recommended Products
