Best Headlight Upgrades for 1999–2007 Silverado: OEM Replacement to Projector Retrofits
GMT800 Silverado headlights from the factory are hazy, dim, and dated. Whether you want better night visibility, a cleaner look, or both — there are solid options at every price point.
STOCK LIMITATIONS
  • Factory Base system sounds good but head unit is limited to CD and AM/FM
  • Factory polycarbonate lens hazes over with UV exposure — kills light output
  • Reflector-style factory housing creates a wide, low-intensity beam pattern
  • No projector option from the factory — beam cutoff is soft and scattered
COMMON ISSUES WITH FACTORY HEADLIGHTS
  • Driver seat bolster cracking from entry and exit wear
  • Cloth seats stain permanently from work use
  • UV damage turns the lens yellow and reduces output
OPTIONS
OEM Replacement LEDs (plug-and-play)
  • Drop-in LED bulbs for H13 socket — no relay needed on most GMT800s
  • Output improvement over stock halogen but limited by reflector housing
  • Easy install — 20 minutes per side
Projector Retrofit Housings
  • Replace the entire headlight housing with a projector unit
  • Clean beam cutoff, focused output, dramatic improvement in night visibility
  • Requires wiring check — most are plug-and-play on GMT800
Headlight Restoration
  • If lenses are hazy, restore before replacing
  • 3M or Meguiar’s kits work well on polycarbonate lenses
  • Add UV sealant after — they’ll haze again within a year without it
Recommended Parts
