Best Floor Mats for Classic C10 – Custom vs Universal Fit
Floor mat choice for a classic C10 comes down to your use case. Here are the best options.
Classic C10 Floor Pan Configuration
The 1947–1972 C10 floor is a simple flat floor with a transmission tunnel. The floor pan is relatively flat compared to modern trucks, which makes fitting aftermarket mats fairly easy.
Option 1: Rubber Floor Mats (Best for Work Trucks)
Universal rubber floor mats cut to size work perfectly in classic C10s. They’re waterproof, durable, and easy to clean. Measure your floor dimensions and order heavy-duty rubber mat material from an auto parts store.
Option 2: Custom Loop Carpet
For a cleaner look, loop or cut-pile carpet from a restoration supplier creates a nice finished appearance. LMC Truck and Classic Industries offer restoration-correct carpet kits cut to your specific floor configuration.
Option 3: Universal Mats
The FH Group Universal Seat Covers brand also makes floor mats that work as a quick, affordable solution.
Floor Sealing First
Before laying any new floor material, ensure the floor is:
  1. Rust treated with Rust-Oleum 2-in-1 Rust Reformer
  2. Sealed with sound deadening or rubberized undercoating
  3. Covered with mass-loaded vinyl (MLV) for heat and noise reduction
This investment significantly improves the driving experience and prevents future rust.
