Best Cold Air Intake for GMT900 6.2 – Top Picks
The 6.2L L9H engine in the 2007–2013 Sierra/Silverado and Escalade is one of the most underrated V8s GM ever built. Adding a cold air intake is one of the best bang-for-the-buck mods you can do. Here’s what works best.
Why Upgrade the Intake on the 6.2L?
The factory airbox is somewhat restrictive, especially at high RPM. A quality cold air intake can free up 15–25 horsepower and improve throttle response noticeably.
Top Pick: K&N 57-3070 Cold Air Intake
This is the most popular and well-reviewed cold air intake for the GMT900 6.2L platform. It fits 2007–2014 Silverado, Sierra, Tahoe, Suburban, Yukon, and Escalade with the 6.2L engine.
K&N 57-3070 Cold Air Intake – 2009–2014 Chevy/GMC/Cadillac 6.2L
Features:
  • High-flow oiled cotton gauze filter
  • Aluminum intake tube for heat management
  • Airflow improvement of up to 50% over stock
  • Washable and reusable filter – never buy a paper filter again
  • Comes with CARB EO number for legal use in most states
Installation:
  • Difficulty: Easy (30–45 minutes)
  • Tools needed: 8mm socket, flathead screwdriver, pliers
  • Fits in the factory airbox location with minor modifications
Real World Results:
Most owners report a noticeable seat-of-the-pants improvement in throttle response and a satisfying induction sound at WOT. Dyno results typically show 12–20 whp gain on a stock 6.2L.
Alternative Options:
  • Volant 15857 intake – Similar gains, uses oiled filter
  • S&B 75-5062 intake – Dry filter option, excellent filtration
Maintenance:
Clean the K&N filter every 50,000 miles under normal conditions. Use the K&N Recharger Kit for cleaning.
What intake are you running on your 6.2? Share your results below!
Upgrading the intake on these trucks really helps clean up airflow and gives you better throttle response overall. I actually picked up an EngineGo 6.7 Cummins Delete Pipe for my diesel setup recently and noticed a massive difference in performance right away. Getting rid of those bottlenecks always makes a huge impact!
