Your classic C10’s bench seat takes a beating over the decades. Whether you’re restoring a tired original or freshening up a daily driver, the right seat cover makes a huge difference.
Why Seat Covers for a Classic C10?
Original vinyl is brittle after 50+ years. Replacement seat covers are far cheaper than reupholstery and give you flexibility to change styles. Plus, if you’re using the truck, covers protect your investment.
Option 1: Universal Bench Seat Covers
Universal bench seat covers work well on the simple bench design of classic C10s. The FH Group Universal Seat Covers in black, gray, or tan can be fitted to the bench seat with elastic backing. They’re washable, affordable, and look decent.
Option 2: Fitted/Custom Covers
TMI Products and LMC Truck offer direct-fit covers for specific year C10 ranges. These fit like a glove and use period-correct vinyl patterns. More expensive but professional results.
Option 3: Full Reupholstery
If you’re doing a show build, send the seats to an upholstery shop. Custom two-tone vinyl, pleated patterns, or leather inserts can be done for $400–800 per seat.
Tips:
- If your foam is crumbling, replace it before covering — a new cover won’t fix lumpy foam
- Use a heat gun to shrink the vinyl after installation for a tighter fit
- Vinyl restoration spray (SEM Color Coat) can match small uncovered areas
What look are you going for on your build?
