The battery in your full-size Chevy truck needs to handle cold starts, accessory loads, and diesel glow plugs if applicable. Here’s how to choose the right one.
Battery Group Sizes for Silverado:
- Most Silverado 1500 gasoline: Group 78 or Group 34/78
- Silverado 2500/3500 diesel: Group 65 or Group 94R
- Always verify in your owner’s manual — configurations vary by engine
What CCA Means:
Cold Cranking Amps (CCA) is the battery’s ability to crank the engine at 0°F. Higher CCA = better cold weather starting.
For gasoline Silverado:
- Minimum: 600 CCA
- Better: 750-800 CCA
For diesel Silverado:
- Minimum: 770 CCA
- Better: 850-1000 CCA
Best Battery Options:
1. Optima Yellowtop (Best Overall)
Optima’s AGM batteries are the performance choice for trucks with high accessory loads. The Yellowtop is designed for deep cycle + starting use — perfect for trucks with winches, inverters, or light bars.
2. ACDelco Advantage Group 78 (Best OEM Replacement)
ACDelco makes OEM-quality batteries at competitive prices. The Advantage series offers solid CCA ratings with GM’s backing.
3. Interstate MTX-78/86 (Best Value)
Interstate batteries have an excellent reputation for longevity at mainstream prices.
Dual Battery Setup:
For trucks with heavy accessory loads, consider a dual battery isolator setup. An AGM auxiliary battery dedicated to accessories (lights, winch, fridge) keeps the starting battery at full charge.
The Mobil 1 5W-30 Full Synthetic is also worth upgrading at the same time as a battery — both are maintenance items worth doing together.
