Best 6 Inch Lift for K2XX Sierra – Wheel & Tire Guide
The 2014–2018 K2XX Sierra/Silverado is a popular lift platform. Going 6 inches opens up room for 35–37" tires. Here’s how to do it right.
K2XX Suspension Overview:
The K2XX 1500 uses strut-based IFS up front with torsion key removal on 4WD models. It’s similar in design to the GMT900 platform.
6" Lift Components:
  1. Front: 3.5"–4" strut spacer + extended upper control arms
  2. Rear: 3" add-a-leaf or 4" block + U-bolts
Upper Control Arms (Mandatory at 6"):
Aftermarket UCAs (Cognito, Tuff Country, McGaughy’s) reposition the upper ball joint to maintain proper CV angle and alignment geometry.
3.5/3 inch Lift Kit:
3.5" Front + 3" Rear Lift Kit for 2007–2018 Silverado/Sierra 1500 – A good starting point for most builds.
Tire Fitment at 6":
  • 33" (285/70R17): Fits without modification
  • 35" (315/70R17 or 35x12.50R17): Fits with minor trimming
  • 37": Requires fender mods
Wheel Offset:
For 35" tires, look for wheels with 0 to -12mm offset to avoid rubbing on the UCAs.
Alignment:
After a 6" lift with UCAs, a proper 4-wheel alignment is essential. The UCAs have adjustment for caster. Budget $150 for a quality lift alignment.
Shocks:
Factory shocks won’t work at 6". Use Bilstein 5100 or Fox shocks specifically rated for your lift height.
What lift are you running on your K2XX? Share your tire size and setup!
