Upgrading to 5th wheel towing requires the right hitch and the right setup. Here’s a complete guide for Silverado 3500 owners.
Why 5th Wheel vs. Conventional?
5th wheel hitches mount in the truck bed and attach to a kingpin on the trailer. This design:
- Enables much higher tongue weight capacity
- Provides better stability at highway speeds
- Allows more precise maneuvering
- Supports gooseneck trailers with adapters
Silverado 3500 5th Wheel Capacity:
The Silverado 3500 HD with the 6.6L Duramax is rated up to 36,000 lbs 5th wheel towing on single rear wheel configurations, and more on dually configurations. Always verify your truck’s specific rating in the tow guide.
Best 5th Wheel Hitches:
1. Reese Towpower 30089 (Best Value)
An established mid-range 5th wheel at around $400-600. 16,000 lb capacity, compact design that allows good bed access.
2. B&W Companion RVK3075
The Reese 5th Wheel Hitch 20,000 lb is one of the best-selling 5th wheels for Silverado platforms. 20,000 lb capacity with a clean design.
3. Andersen Hitches No-Sway 5th Wheel
Andersen’s innovative design uses rubber mounting rather than roller bearings for ultra-quiet operation and zero slop.
Bed Rail Compatibility:
The Silverado 3500 uses GM’s standard bed rail system. Many 5th wheel hitches use Reese’s “Under Bed” rail system that hides most of the hitch below the bed floor when not in use.
What trailer are you planning to pull?
