Apple CarPlay Head Unit Install in Silverado – What You Need
Installing an Apple CarPlay head unit in a Silverado is a popular upgrade. Here’s what you need and how the process works.
What You’ll Need:
  1. Double DIN Head Unit with CarPlay – The Kissound 7" Double DIN is a popular budget option with wireless CarPlay
  2. Dash kit – Vehicle-specific from Metra (Metra 99-3000T for most Silverados)
  3. Wiring harness adapter – Converts GM connector to aftermarket standard (Metra 70-2003 series)
  4. Antenna adapter – For FM reception (Metra 40-GM10)
  5. Optional: Backup camera – The GLK License Plate Camera works great
Installation Process Overview:
  1. Disconnect the battery negative terminal
  2. Remove the factory radio trim panel (typically 4 plastic clips and 2 screws)
  3. Unscrew the factory radio (usually 2-4 screws)
  4. Disconnect the wiring harness and antenna lead
  5. Connect the harness adapter to the factory connector
  6. Connect the adapter to the head unit
  7. Connect antenna and camera leads
  8. Test before reassembly — verify CarPlay, backup camera, radio
  9. Mount using the dash kit and trim ring
  10. Reconnect battery, perform final test
Common Issues:
  • No sound from factory speakers: Check if your Silverado has a factory amp (common on Bose systems) — may need a PAC or AudioControl LOC
  • Screen brightness issues: Calibrate screen brightness in settings
  • GPS not working: Verify GPS antenna placement under the dash away from metal
Total Budget: $120-200 including head unit, dash kit, and wiring adapter.
