AFM Delete vs Disable on GMT900 (What Actually Works)
AFM Delete vs Disable on GMT900 — What Actually Works
If you own a GMT900 5.3L, you’ve likely already heard about Active Fuel Management (AFM) and the problems it causes. The two main solutions are disabling it or deleting it — but they are not the same thing, and the difference matters.
What AFM Does (and Why It’s a Problem)
GM’s Active Fuel Management (also called DoD — Displacement on Demand) deactivates cylinders 1, 4, 6, and 7 at light throttle to improve fuel economy. In theory it works. In practice, it creates a set of well-documented issues:
  • Increased oil consumption due to pressure fluctuations pulling oil past valve seals
  • Accelerated lifter wear, especially on the AFM lifters themselves
  • Engine vibration or slight roughness when switching between V4 and V8 mode
  • Risk of catastrophic lifter failure, particularly on higher-mileage engines
Option 1: AFM Disable (Quick and Reversible)
How it works: A plug-in device like the Range Technology AFM Disabler plugs into the OBD-II port and keeps the engine in V8 mode at all times. It prevents the ECU from activating cylinder deactivation.
Pros:
  • Inexpensive (~$70–$90 USD)
  • No tuning or mechanical work required
  • Completely reversible
  • Works immediately
Cons:
  • Does NOT fix existing wear or damage
  • Does NOT replace worn AFM lifters
  • Relies on a device being plugged in at all times
  • Not a tuned solution — may affect other parameters depending on the device
Best for: Trucks with lower mileage, no existing symptoms, or as a stop-gap while planning a full delete.
Option 2: AFM Delete (Permanent and Correct)
How it works: The AFM components are physically removed and replaced with standard parts. This includes replacing all 16 lifters (including the special AFM lifters), installing a standard valley cover (without the VLOM solenoid), and retuning the ECU to operate without AFM.
What’s typically included:
  • 16 standard (non-AFM) LS lifters
  • Standard valley cover / VLOM delete plate
  • Custom ECU tune to remove AFM programming
  • Optional: upgraded camshaft and valve springs for additional performance
Pros:
  • Permanently eliminates the root cause
  • Prevents lifter failure
  • Allows for a proper performance tune at the same time
  • Better throttle response and smoother power delivery
  • Reduces oil consumption significantly
Cons:
  • Higher cost ($800–$2,500+ depending on who does the work and what parts are used)
  • Requires engine disassembly (top end)
Best for: Any truck showing oil consumption, any truck that’s had AFM-related codes, or any truck being tuned for performance.
Which One Should You Choose?
If your truck is under 80,000 km with no symptoms: Start with the disable device while budgeting for the full delete.
If you have oil consumption, misfires, or ticking lifters: Skip the disable device. Go straight to the full delete. The money you spend on the disabler first is money not going toward the real fix.
If you’re already doing a tune: Always bundle the AFM delete with the tune. The cost difference is minor at that point and the result is significantly better.
Recommended Products
