Active Fuel Management (AFM), also called Displacement on Demand (DoD), was introduced on 2007+ GMT800 trucks with the 5.3L LS engine. On high-mileage trucks it causes collapsed lifters, excessive oil consumption, and engine damage.
SYMPTOMS OF AFM FAILURE
- Oil consumption of 1 quart or more per 1,000 miles
- Ticking or knocking noise from the valley of the engine
- Check engine light with misfire codes on cylinders 1, 4, 6, 7
- Rough idle that gets worse over time
HOW AFM WORKS (AND FAILS)
- AFM deactivates cylinders 1, 4, 6, 7 under light load to save fuel
- Special AFM lifters use an internal oil pressure mechanism to collapse
- Over time the oil passages in the lifter body get stuck — lifter doesn’t re-extend
- Result: collapsed lifter, wiped cam lobe, metal debris in the oiling system
AFM DELETE OPTIONS
- Software delete only: Use HPTuners or EFI Live to disable AFM in the tune — free if you already have a tuner. This stops the activation but the fragile AFM lifters are still in there.
- Full mechanical delete: Replace all 16 lifters with standard LS7 or LS3 non-AFM lifters, swap the valley cover for a non-AFM version, and retune.
FULL DELETE STEPS
- Pull the intake manifold
- Remove the valley cover
- Drop the pushrods — label them if reusing
- Pull all 16 lifters — DO NOT mix up the bores
- Install LS7 or LS3 solid or standard lifters
- Install a non-AFM valley cover (no solenoids)
- Reassemble with new intake gaskets
- Tune out AFM with HPTuners or EFI Live
