The K2XX generation (2014–2018) Silverado/Sierra was offered with both a 6-speed (6L80) and an 8-speed (8L90) automatic transmission. Which is more reliable?
6L80 6-Speed (Most K2XX Trucks):
- Used with 5.3L EcoTec3 (standard application)
- Proven reliable transmission with extensive field history
- Similar design to the 6L90 in HD trucks
- Max torque: ~650 ft-lbs
- Generally considered the more proven option
8L90 8-Speed (High Country, LTZ Z71, 6.2L Applications):
- Used with 6.2L EcoTec3
- Provides more gear ratios for better fuel economy
- Relatively new design at K2XX launch
- More complex shifting behavior
- Some early production issues with shudder and hunting
Common 8L90 Issues:
- Torque converter shudder (similar to 6L80 issues)
- Transmission hunting between gears (frequent gear changes)
- Clunks during low-speed maneuvering
6L80 Common Issues:
- TCC shudder at cruise (fixable with fluid service)
- 4th gear clutch wear at high mileage
Which Is More Reliable?
The 6L80 has a longer track record with fewer documented issues. The 8L90 is a newer design that has improved with calibration updates.
Fluid for Both:
ACDelco Dexron VI ATF – OEM-specified fluid for both 6L80 and 8L90. Service every 45,000 miles under normal use, 30,000 miles under towing.
Bottom Line:
The 6L80 is the safer choice for long-term reliability. The 8L90 is getting better but has more complex behavior.
Which trans does your K2XX have? Any issues to report?
