5.3 vs 6.0 Engine Differences – LM7 vs LQ4 (GMT800 Guide)
One of the most common questions on GMT800 trucks: what’s actually different between the 5.3 and the 6.0, and does it matter for your build? Here’s the full breakdown.
Quick Reference
Spec 5.3L LM7 / L59 6.0L LQ4 / LQ9
Displacement 325 ci (5,328 cc) 364 ci (5,967 cc)
Bore x Stroke 3.78" x 3.62" 4.00" x 3.62"
Stock HP (LM7) 270–285 hp 300–325 hp
Stock TQ (LM7) 315–325 lb-ft 360–370 lb-ft
Block Iron Iron
Heads Aluminum (cathedral port) Aluminum (cathedral port)
Compression 9.5:1 9.4:1
Firing Order 1-8-7-2-6-5-4-3 1-8-7-2-6-5-4-3
Flex Fuel option L59 (yes) No
Truck application 1500 2500/3500
Engine Codes to Know
5.3L variants:
  • LM7 – Standard iron block, aluminum heads, most common in 1500s
  • L59 – Flex fuel version of the LM7 (ran E85)
  • LM4 – Aluminum block 5.3, rare in trucks, found more in SUVs
6.0L variants:
  • LQ4 – Standard 6.0, most common in 2500/3500 trucks and Suburbans
  • LQ9 – Higher compression version (10.1:1), found in Escalade EXT and some HD trucks — also called the “Hot” 6.0
Real World Differences
Power: The 6.0 makes more torque down low and holds it longer. You’ll feel it towing or moving heavier loads. For a stock daily driver 1500, the 5.3 is plenty.
Swap potential: The 6.0 has a larger bore and responds better to cam and head upgrades. If you’re building for power, a 6.0 block is a better foundation. That said, a cammed 5.3 with ported heads is still a solid truck.
Fuel economy: The 5.3 is more efficient. Expect 1–2 mpg better than the 6.0 in similar conditions, especially with the AFM-equipped versions (post-2007 on GMT800 is rare, but exists in some late models).
Parts: Both use the same LS-platform parts — heads, intakes, cams, sensors all interchange. The 6.0 uses a slightly different head bolt pattern in some configurations, so always verify fitment when swapping heads across displacement.
Reliability: Both are extremely reliable with basic maintenance. The LQ4 in heavy-duty applications sometimes sees more wear on bearings if oil maintenance is neglected, simply because it sees harder use.
Common RPO Codes
  • L18 = 8.1L (not LS, separate engine entirely)
  • LM7 = 5.3L standard
  • L59 = 5.3L flex fuel
  • LQ4 = 6.0L standard
  • LQ9 = 6.0L high output
You can find your engine RPO code on the sticker in the glove box.
Bottom line: If you have a 1500, you have a 5.3 — and it’s a great engine. If you’re swapping into a build or want more displacement for hauling, the 6.0 LQ4 is the obvious upgrade. Both are LS family, so the swap path is straightforward.
What are you running? Drop your RPO code below.
