A 3–4 inch lift on a Squarebody K10 or K20 is the sweet spot for most builds. You get tire clearance without destroying the front geometry or needing a ton of supporting mods.
SETUP OPTIONS
- Body lift (1–3 inch): Separates body from frame — no suspension geometry change
- Suspension lift (3–4 inch): Raises the whole truck — better for off-road
- Combo: 2-inch body lift plus 2-inch suspension lift for clearance without complexity
PROS
- 33s fit easily under a 3-inch suspension lift
- 35s fit with a 4-inch lift and minor trimming on K10s
- Better approach and departure angles for trail use
- Improved ground clearance under differentials
CONS
- Front CV angles get aggressive with 4+ inch suspension lifts on K20s
- Steering geometry changes — expect more bump steer without correction
- Factory brake lines may need extensions
- Adds stress to factory front axle U-joints at full droop
RIDE QUALITY
- A quality kit with new shocks rides better than stock on tired suspension
- Cheap kits use low-grade steel and flex under load
- Pair with new shocks for best results — don’t reuse 40-year-old units
TIRE FITMENT
- 33x12.5 fits a 3-inch lift with mild backspacing adjustments
- 35x12.5 requires 4 inches and possible front bumper trimming
- Measure before ordering — early and late Squarebody years differ slightly
WHAT TO AVOID
- Spacer-only lift kits for 4x4 use — they stress the factory CV joints
- Unknown brand kits from marketplace sellers
- Skipping an alignment after any suspension change
Recommended Parts
- 3" Front Coil Spring Spacer Leveling Lift Kit for 1967-2004 C10/K10: Amazon.com
- Gabriel Load Carrier 34036 Front Shocks for Chevy C10/K10: Amazon.com
