The 3.0L Duramax LM2 inline-6 diesel debuted in the 2020 T1XX Silverado/Sierra 1500. It’s one of the most fuel-efficient and unique powertrain options available in a half-ton truck. Here’s what owners are finding after several years of real-world use.
3.0L Duramax LM2 Specs:
- 277 HP / 460 ft-lbs torque
- 6-cylinder inline configuration
- DEF (diesel exhaust fluid) required
- Combined fuel economy: ~27–30 MPG (excellent for a 1500 truck)
- Maximum tow rating: 9,300 lbs (1500 series)
Long-Term Reliability Observations:
Positives:
- Low fuel costs (diesel + excellent economy = strong value)
- Smooth, quiet operation for a diesel
- Strong torque for light to moderate towing
- High-quality Bosch injection system
Documented Issues:
- DEF system failures: Like all modern diesel DEF systems, the LM2 has seen some DEF heater and sensor issues in cold climates
- Timing chain noise: Some early units reported timing chain ticking – addressed by GM with updated calibrations
- Fuel contamination concerns: Less common than the CP4-equipped Duramax diesels, but fuel quality still matters
Maintenance Requirements:
- DEF fluid: BlueDEF DEF Fluid – top up as needed (approximately every 4–6 oil changes)
- Oil: Full synthetic diesel-rated oil, approximately 10,000-mile intervals
- Fuel filter: Every 25,000 miles recommended
Best Use Case:
The 3.0 Duramax excels as a highway towing truck and daily driver. For those who tow over 8,000 lbs frequently, the 6.6L Duramax in the 2500HD is still the better choice.
Are you running a 3.0 Duramax in your T1XX? Share your mileage and experience!
