2017 Silverado Intermittent Heavy Vibration when Braking
Been having trouble with my Silverado 1500. It started with an intermittent vibration when driving that got much worse under braking. I replaced the rotors, pads, and calipers on the front, new rotors and pads on the back. They were worn, so I figured it cured it. After a week or so, it came back. I talked to a friend who is a retired Chevy Dealership mechanic, and he said to replace the front brake hoses. I did that and the problem was solved, for about a year. It’s back again. I’ve ordered new hoses again and will replace them this next weekend, hoping for the best. Has anyone else run across this problem? Thanks!
Hi there and thank you for posting! I haven’t run across that exact one yet, but a few things come to mind and my first thought is trapped pressure inside of a brake line (caused by MC or pedal not returning, or maybe ABS module not operating properly), causing a brake to drag intermittently.
How bad is the vibration when driving? Does it get worse the more you drive (and the more your brake)?. If so, I’d be checking for brake drag with the front wheels off the ground. Jack the front end up, spin each wheel normally (noting any brake drag without brakes depressed). Check both sides, also check wheel bearings as well. If all seems fine with wheels off the ground when it’s cold I’d then take it for a quick test ride.
Take it for a burn up to operating temp, with some normal stops, then try it again. Jack it up again, spin wheels again, checking both sides. If one is noticeably tighter than it was cold or than the other one, that would be the problem area/line and from there you have a starting point to look at.
It sounds to me like it could be a caliper not releasing - air bubble in the system etc. Culprit could be master cylinder or pedal not returning or even the ABS module holding a valve partly closed!
Hopefully that is a bit of help - best of luck getting it back up and operational!
IF you do end up finding the fix don’t hesitate to post what fixed it for our future readers!
I went ahead and ordered new lines for both sides and installed them on Saturday. So far, so good. the vibration is gone, at least for now. I’ve had a couple of mechanics tell me that some of the hoses do ten to go bad. we’ll see. Thanks.
Excellent well I am glad it seems to have gone away for you!
It does seem very odd that the newer brake hoses tend to go bad!
Glad the second set of hoses got you back on the road. If it does come back, an infrared thermometer at the two front wheels right after a short drive with a couple of normal stops gives you numbers to compare instead of a feeling. Read the same spot on each rotor hat or caliper bracket within a few seconds of parking, and write the two numbers down. A caliper that is not fully releasing on one side shows up as a clear temperature spread between left and right.
I chased what looked like warped rotors on my own truck and it turned out to be a sticking slide pin: the pad dragged, heated that rotor unevenly, and the runout followed on the next hard stop. Same heavy vibration under braking as a warped disc, but new rotors would not have fixed it. Logging the two temperatures after each drive lets you catch the trend early instead of after another round of parts.
