“Service Stabilitrak” might be the most parts-cannoned message on the GMT900 platform. It’s not a diagnosis — it just means the stability system saw data it couldn’t trust. The actual fix has been everything from a $15 brake light switch to a wheel hub to a corroded connector under the truck.
The pattern that keeps showing up: the answer is in the ABS module codes, not the engine codes. C0710 points at the steering wheel position sensor (or just its corroded connector), wheel-speed codes name the corner, and if there’s a misfire code, the Stabilitrak message is usually just along for the ride.
Full ranked-causes diagnostic guide here: Service Stabilitrak: Real Causes Ranked
Let’s build a real fix database for these trucks:
- Year, engine, and when does the message appear? (on turns, cold start, random?)
- What codes were stored in the ABS module?
- What part — or connector cleaning — finally made it stay gone?
- Anyone chase one of these for months? What was the dead end that wasted the most money?
