SBC 327 vs 350 – Which Is Better for a Classic Truck Build?
Both the 327 and 350 are legendary small blocks, but they suit different builds. Here’s the breakdown for classic truck guys.
SBC 327 – High-Revving and Smooth
The 327 was offered from 1962–1969 and is beloved for its high-RPM character. It produces excellent horsepower per cubic inch, especially in higher compression builds. If you want a factory-correct engine for a 1960s C10, the 327 is the authentic choice.
Weaknesses: crankshafts are more expensive, short-stroke means less torque down low (important for truck use), and they’re harder to find.
SBC 350 – The Better Truck Motor
The 350 has more displacement and a longer stroke, which means more torque in the lower RPM range where trucks spend most of their time. It’s cheaper to rebuild, parts are everywhere, and the power potential is enormous.
For a street truck that hauls, tows, or needs daily manners, the 350 wins. A performance carb like the Edelbrock 1407 750 CFM pairs perfectly with a mild cam and Edelbrock intake.
Verdict
  • Purist show build: 327 for authenticity
  • Driver/restomod: 350 for torque and parts availability
What does your build call for?
