LS Swap into 73–87 C10 – Complete Wiring Harness Guide
The 1973–1987 C10 is the most popular LS swap platform in existence, and for good reason. The engine bays are large, the chassis is simple, and the result looks factory-clean. The wiring is the most intimidating part of the swap – here’s the complete guide.
Why the Wiring Stresses People Out
The LS engine family uses a fully computer-controlled system. To run an LS in a C10 that had a carbureted SBC, you need to either:
  1. Use a pre-made standalone harness (easiest)
  2. Modify the factory truck harness
  3. Build a custom harness from scratch
Option 1: Standalone Harness (Recommended for Most Builds)
A standalone LS harness strips out all the non-essential wiring from the factory ECM harness, leaving only what’s needed to run the engine. You keep your factory C10 body wiring completely separate.
Painless Performance 60508 LS1 Standalone Harness – The gold standard for LS swaps. Fits 1998–2002 LS1 engines, includes all sensors and connections.
What the Harness Connects:
  • ECM/PCM
  • Fuel injectors (all 8)
  • Ignition coils
  • Crankshaft/camshaft position sensors
  • MAP sensor, MAF sensor
  • Throttle body (TPS, IAC)
  • O2 sensors (4 wires to your O2 bungs)
  • Oil pressure, coolant temp sensors
Fuel System Requirements:
The LS requires a high-pressure fuel injection system. You’ll need:
  • Returnless fuel pump setup (recommended) or return-style EFI pump
  • Fuel pressure of 58 psi (LS1) or 62 psi (Vortec truck engines)
  • Stainless or EFI-rated fuel line
What ECM to Use:
  • LS1 (F-body, 1997–2002): Most common swap engine – use stock ECM with standalone harness
  • LS Vortec trucks (4.8/5.3/6.0, 1999+): Works great, requires appropriate harness
PCM Programming:
The ECM needs to be tuned for your specific setup (cam, injectors, idle). Use HP Tuners or EFI Live for custom calibrations.
Have questions about your specific LS swap harness situation? Post your engine and year combo below.
