How to Wire Aftermarket Gauges in Classic Chevy Truck – Full Guide
Wiring aftermarket gauges in a classic C10 is one of the most rewarding projects you can tackle — but it can also be frustrating if you don’t understand the basics. This thread is a complete guide to gauge wiring for classic trucks.
We cover sender types (temperature, oil, fuel), signal wire routing, ground loops and their elimination, gauge light wiring, and how to handle ignition-switched power properly. We also discuss using a voltage stabilizer for more accurate fuel gauge readings.
For a complete factory-correct but modern wiring solution, the Painless 10101 21-Circuit Harness is purpose-built for classic C10 trucks and makes gauge wiring much cleaner than piecing together circuits from the factory loom.
Share your gauge wiring tips and any lessons learned.
