How to Add Bluetooth to a Classic Chevy Truck – Simple Options
You don’t need to replace the entire radio to get Bluetooth in your classic C10. Here are several approaches from simple to comprehensive.
Option 1: FM Bluetooth Transmitter (Easiest)
A Bluetooth FM transmitter plugs into the 12V accessory outlet and transmits audio to any FM frequency. You tune your factory radio to that frequency and stream from your phone.
Pros: No installation, works with any existing radio
Cons: Audio quality is mediocre, FM interference in some areas
Option 2: Aux Input Adapter
If you can access the back of the original radio, an aux input adapter module connects to the internal audio path. You then use a Bluetooth-to-aux adapter plugged into the new aux input.
Better audio quality than FM transmitter.
Option 3: Full Head Unit Replacement (Best)
The cleanest solution is a full head unit replacement. A Kissound 7" Double DIN or similar unit provides Bluetooth plus Apple CarPlay, backup camera input, and full audio control.
The installation requires some dash modification but delivers the best long-term experience.
Bluetooth Speaker Adapter
For trucks that just need to take phone calls, a Bluetooth visor speakerphone is a $20 solution that works with any vehicle.
Wiring Note
Before any stereo work, consider whether the factory wiring needs attention. The Painless 10101 Classic Chassis Harness is worth considering if the wiring is original — it eliminates decades of gremlins.
