The factory wiring on a 1947–1972 Chevy truck is 50+ years old. Brittle insulation, corroded grounds, and spliced repairs are common. Here’s when and how to rewire.
Signs It’s Time to Rewire:
- Intermittent electrical gremlins with no clear cause
- Burning smell from dash or firewall
- Melted insulation around fuse block
- Multiple splices and non-factory repairs in the harness
- Engine swap that requires new engine bay wiring
Best Options for a Rewire:
1. Painless Performance 10101 Classic Chassis Harness
The Painless 10101 Classic Chassis Harness is the gold standard for complete classic truck rewires. It’s a 21-circuit harness designed specifically for the GM keyed column. Everything is labeled, fused, and laid out logically.
Price: ~$350–450 depending on vendor.
2. Painless 60508 for LS Swaps
If you’ve already done or are planning an LS swap, the Painless 60508 LS Swap Harness handles the engine side. Use it with the 10101 body harness for a complete system.
3. Ron Francis Wiring
Ron Francis makes excellent pre-assembled harnesses with similar quality to Painless. Good alternative if pricing varies.
DIY Tips:
- Use the factory color coding as reference
- Route new harness in the same paths as stock
- Always use proper butt connectors and heat shrink, never twist and tape
- Install a main fuse block under the hood for modern safety
What symptoms are you seeing? Let’s diagnose.
