Classic Chevy Truck Headliner Replacement – DIY Guide
The original headliner in a 1947–1972 classic C10 has likely sagged, stained, or fallen by now. Here’s how to approach the replacement.
Classic C10 Headliner Construction
Early C10s used a bowed headliner style with horizontal bows that support the headliner material. The bows run front to back and clip into channels on each side of the cab.
The headliner material was originally vinyl or cloth, held in place by the bows and pressed under the drip rail molding.
DIY Replacement Steps:
  1. Remove the drip rail molding – The chrome drip rail clips off with a trim removal tool
  2. Remove sun visors and dome light – These pierce the headliner material
  3. Remove the bows – Slide them out of their channels
  4. Remove old headliner material – Old foam-backed material often crumbles; wear a mask
  5. Clean the cab ceiling – Remove all old foam residue and rust treat any surface corrosion
  6. Cut new material – Use the old piece as a template, add 2–3" margin
  7. Thread the bows – New material comes with pre-stitched bow sleeves on quality kits
  8. Reinstall and tension – Bows go back in channels and tension the material flat
  9. Trim and tuck – Trim excess and tuck under drip rail molding before reinstallation
Material Choices:
  • Vinyl: Period-correct, durable, easy to clean
  • Cloth/perforated vinyl: More breathable for hot climates
  • Custom colors/patterns: Transform the interior aesthetics
Use Chemical Guys HydroSlick on the exterior while the truck is accessible during the headliner job.
