Door skins on classic C10 trucks are one of the most common rust areas, especially in the lower corners where water traps behind the trim. Replacing a door skin is a weekend job if you have basic bodywork skills and the right tools.
This thread walks through the process: removing the old skin, straightening the inner structure, welding or bonding the new skin, and finishing for paint. We also discuss hammer and dolly techniques and whether to go bare steel or galvanized replacements.
For frame and structural rust on the classic C10, check our thread on Best Rust Converter for Classic C10 Frame. Using a quality rust reformer like the Rust-Oleum Reform Spray on treated areas before priming helps prevent future problems.
Share your door skin replacement tips and pics below.
