Squarebody trucks (1973–1987) used carbureted fuel systems from the factory — primarily the Rochester Quadrajet 4-barrel on V8 models and a 2-barrel Rochester on smaller engines. Here’s what you need to know about tuning, diagnosing, and upgrading your fuel system.
Know Your Carburetor
1973–1984 (pre-TBI): Rochester Quadrajet (Q-Jet) 4-barrel on most V8s. The Q-Jet is a solid carb when properly tuned — variable venturi design with good fuel economy and decent performance.
1985–1987: Some models got early TBI (Throttle Body Injection), particularly the 4.3L V6 and later the 5.0/5.7L. If you have TBI, this guide mostly applies to carb-swapped trucks.
Common Quadrajet Problems & Fixes
| Problem | Likely Cause | Fix |
| Hard hot start, flooding | Power valve blown | Rebuild kit + new power valve |
| Lean stumble off-idle | Worn idle passages | Clean with spray carb cleaner; rebuild |
| Rich black smoke | Float level too high | Adjust float; rebuild |
| Surging idle | Air leak at base gasket | New base gasket; check intake torque |
| Hesitation on acceleration | Accelerator pump worn | Rebuild kit |
Best solution for most Q-Jet issues: Full rebuild with a quality kit. A good rebuild takes about 2 hours and costs under $30 in parts.
Q-Jet Rebuild Basics
- Remove the carb — label vacuum lines before disconnecting
- Disassemble in a clean area (newspaper or paper towels to catch small parts)
- Soak all metal parts in carb cleaner dip basket for 30–60 min
- Blow out all passages with compressed air
- Install new gaskets, power valve, and accelerator pump from rebuild kit
- Set float level per spec (usually 3/16" to 7/32" from gasket surface)
- Reinstall and set idle mixture screws (1.5 turns out as a baseline)
Replacement Option: If the Q-Jet is too worn or you want to simplify, a Rochester Quadrajet 4-Barrel Replacement Carb offers a bolt-in upgrade for 305–350 engines with electric choke.
Fuel System Basics
Fuel pump: Mechanical pump bolted to the block. Common failure point — if you’re getting raw fuel in the oil, the diaphragm has failed. Replace with a quality OEM-style pump.
Fuel filter: Replace annually. Located inline near the carb on most years. Use a brass fitting filter, not plastic.
Fuel lines: Stock steel lines are fine if rust-free. Check all connections at the frame for pinhole leaks.
Performance Upgrades
If your goal is more power:
- Bigger Q-Jet: 750 CFM Q-Jets from donor 454 cars can bolt on to 350 trucks with some tuning
- Swap to Edelbrock: An Edelbrock 600-650 CFM with matching Performer manifold is a popular upgrade — easier to tune, good street performance
- Headers + carb combo: Adding shorty or long-tube headers while carb tuning gives the biggest seat-of-the-pants improvement
Keep the fuel system in good shape first — no tune will fix a weak pump or dirty carb.
