Rotted floor pans are one of the most common issues on 1973–1987 C10s. The good news is that floor pan replacement is a manageable DIY job if you have basic welding skills. Here’s the complete guide.
Assessing the Damage:
Before buying any parts, determine how much pan needs replacing:
- Pull up the carpet and remove the seats
- Check the driver and passenger side floor pans
- Check the trans tunnel and cab corners
- Poke with a screwdriver – soft or holed areas need full replacement
Options for Repair:
Option 1: Patch Panels (Localized Rust)
For smaller rust spots (12" x 12" or less), cut out the bad metal and weld in sheet metal patches. 18-gauge steel works for most floor pan sections.
Option 2: Full Floor Pan Sections
Reproduction floor pan sections are available for the 73–87 C/K trucks (driver side, passenger side, or full floor). These are the cleanest repair option.
Supplies You’ll Need:
- Angle grinder with cutting wheels and flap discs
- MIG welder (preferred) or flux-core welder
- 3M Weld-Thru Coating II – Zinc Based Primer – Apply to mating surfaces before welding to prevent future rust between panels
- Body hammer and dollies
- Seam sealer for finishing
Step-by-Step Process:
- Remove seats, carpet, and sound deadening
- Mark the cut lines (leave 1" overlap with good metal)
- Cut out the rusted pan section with angle grinder
- Clean up the remaining edges – grind to bare shiny metal
- Apply weld-thru primer to both mating surfaces
- Fit new panel – clamp and tack weld in place
- Finish welding with stitch welds (avoid warping)
- Grind welds smooth
- Apply seam sealer to all seams on top and bottom
- Prime and paint underside before installing carpet
Common Mistakes:
- Not treating the mating surfaces before welding (causes rust to return)
- Using too-thin metal for patch panels
- Leaving factory seam sealer intact – it holds moisture
Cost:
- DIY: $200–$500 in materials (full floor pan section + supplies)
- Shop: $800–$2,500 depending on extent of work
Has anyone tackled floor pan replacement on their C10? Share your tips below.
