Boost Leak Diagnosis on Duramax Diesel: Where They Happen and How to Find Them
Boost leaks are one of the most overlooked causes of low power, black smoke, and high EGTs on Duramax diesel trucks. A small crack in an intercooler boot can cost 50–100 horsepower and dramatically increase exhaust temperatures.
WHY BOOST LEAKS HAPPEN
  • Factory intercooler boots are rubber and become brittle with age and heat cycles
  • The clamps loosen over time — especially after boost levels are increased with a tune
  • Compressor wheel housing can also develop cracks on high-mileage turbos
WHERE TO LOOK
  • Intercooler outlet boot (from intercooler to intake)
  • Intercooler inlet boot (from turbo to intercooler)
  • Any clamped connections in the charge air circuit
  • EGR crossover pipe (on applicable models)
HOW TO TEST FOR BOOST LEAKS
  • Use a boost leak tester — pressurizes the intake system with shop air (15–20 psi)
  • Spray soapy water on connections and look for bubbles
  • Listen for audible hissing
  • Some boost leaks only appear under load — hard to find with a static test
COMMON SYMPTOMS
  • Black smoke under acceleration
  • Low boost compared to baseline (use a boost gauge)
  • High EGTs for the amount of power being made
  • Sluggish throttle response
  • Whistling or hissing noise under boost
FIX
  • Replace any cracked or brittle boots with silicone upgrades
  • Use proper T-bolt clamps — not standard worm gear clamps which can loosen
Recommended Parts
