Best Rust Converter for Square Body Frame Rails
Treating rust on your 73–87 C10 frame is essential for preservation. The right rust converter can stop active rust and give you a paintable surface. Here’s what works best.
What Is a Rust Converter?
Rust converters chemically react with iron oxide (rust) to create a more stable compound (usually iron phosphate or iron tannate). This stops further rust progression and creates a primer-like surface for paint or undercoating.
Top Pick:
Rust-Oleum Automotive 2-in-1 Rust Reform & Seal Spray – One of the best consumer-grade rust converters available. Converts rust and seals the surface in one application. Great for frame rails, crossmembers, and under-cab areas.
How to Use It on Frame Rails:
  1. Wire brush or media blast loose scale and flaking rust
  2. Do NOT strip all the way to shiny metal – rust converter needs some rust to react with
  3. Apply converter to all rusty surfaces
  4. Allow to dry fully (usually 24 hours before topcoating)
  5. Apply undercoating or chassis paint over the converted area
Best Application Method for Frame Rails:
  • Use a brush for heavy buildup areas (better penetration)
  • Use spray can for accessible surfaces
  • Use an undercoating spray gun for full frames
After Rust Conversion:
Apply a quality undercoating or chassis paint to seal and protect. Popular choices:
  • Rust-Oleum Professional Undercoating spray
  • POR-15 chassis paint
  • Eastwood Internal Frame Coating (for inside the frame box)
Don’t Forget the Inside:
The inside of the square-section frame rails traps moisture and rusts from the inside out. Drill access holes and use cavity wax or internal frame coating.
Prevention Going Forward:
After treating and painting, annual undercoating inspections are key. Touch up any bare spots before winter/salt season.
What rust treatment are you using on your Square Body? Share your results!
