Rock lights illuminate the underbody of your truck for off-road trail visibility and create a dramatic look when parked. Here are the best options.
What Are Rock Lights?
Rock lights are small LED pods mounted to the underbody, frame, wheel wells, and rocker panels. They illuminate the ground beneath the truck for:
- Night trail riding visibility
- Obstacle detection on rough terrain
- Visual identification of your truck at trail events
- Parking lot attention-getter (RGB color-change models)
Best Rock Light Options:
Budget: Nilight RGB 10-Pod Kit
The Nilight RGB Rock Lights 10-Pod Kit is the go-to budget choice. Features:
- 10 RGB LED pods
- Bluetooth app control + wireless remote
- Music sync mode
- Waterproof construction (IP68)
- Magnetic and screw-mount options
At $40-60, this is excellent value for a complete kit.
Mid-Range: MICTUNING RGB Rock Lights
MICTUNING’s kits are slightly more premium construction with better connectors and longer wire runs.
Premium: Rigid Industries Rock Lights
Rigid’s LED pods are professional-grade with exceptional output. Used extensively in professional off-road racing.
Installation Tips:
- Mount pods in the front frame area, rocker panels, and rear frame for balanced coverage
- Use self-tapping screws into existing frame holes or magnetic mounts
- Route the main power wire to a fused switch panel inside the cab
- Zip tie all wiring away from moving suspension components
The Nilight 25" LED Light Bar pairs well with rock lights for a complete off-road lighting package.
