Washing your full-size truck properly requires the right pressure washer. Here’s how to choose the correct one without damaging the paint.
Pressure Washer Basics:
PSI (pounds per square inch) = cleaning power/force
GPM (gallons per minute) = rinse ability
Cleaning Units = PSI × GPM
For truck washing, you want: 1,200-1,900 PSI + 1.4-1.8 GPM
Recommended Settings for Truck Washing:
| Task | PSI Range |
| Rinse (no soap) | 1,000-1,500 PSI |
| Pre-soak/foam | 800-1,200 PSI |
| Rinse off soap | 1,200-1,500 PSI |
| Undercarriage | 1,500-2,000 PSI |
Avoid: High pressure (2,500+ PSI) directly on paint, trim, rubber seals, or windshield seals. Can strip wax, embed dirt into paint, and damage seals.
Best Electric Pressure Washers for Trucks:
1. Greenworks 1900 PSI Electric (Best Budget)
1,900 PSI at 1.2 GPM. Adequate for basic truck washing. Quiet, easy to store.
2. Sun Joe SPX3000 (Best Value)
1,450-2,030 PSI with dual detergent tanks. Popular for truck/car washing. Good balance of power and price.
3. RYOBI RY142300 (Best Power)
2,300 PSI from RYOBI — good for undercarriage cleaning and heavy-duty use.
Foam Cannon:
Add a foam cannon attachment ($20-40) for pre-soak snow foam application. This loosens dirt before you touch the paint, reducing swirl marks.
Combine with Chemical Guys HydroSlick Ceramic as the final protection layer after washing.
